sixshooterstang
Bird's Eyes Aerial Media
So no solutions to the minor jitters? This gimbal is driving me nuts. Cold  weather hit and the thing got worse.
I am seeing "jitter" issues myself, you can see my earlier post on page 9 of 11 of this thread where I give all the details on my situation. In my case, I was seeing a lot more jitters until I used the PID settings that were suggest earlier in the post. However, I still see the jitter or shake as the camera tilt is adjusted to about 45 degrees from the horizontal. Can you explain your setup and what jitter you are seeing, maybe someone can help us both out. JohnSo no solutions to the minor jitters? This gimbal is driving me nuts. Cold weather hit and the thing got worse.
The minute shake of the camera is also what I consider jitter. In the video you will see the camera is in the stabilized position. It is only when it tilts down that it starts to shake. With this in mind, I thought about what you said. I agree that these units are balanced very well to the GoPro, but if this changes even slightly it could cause this "jitter". However, I would expect this cable to be OK since it is a Tarot part. Still, I decided to check the cable. I provided more slack for the cable, reseated it and tighten the set screw on the camera mount to motor. Now there is no shake!!! So, either I was restricting the motion when it was tilting or the set screw had slipped causing it to be unbalanced??? Not sure, but all appears to be working, so thanks for that suggestion. JohnSo if you unplug the usb video cable from the camera do you still have the tilt problem ? I dont consider that jitter, I consider minute shaking of the camera as a jitter. I would try to increase the tilt motor power a little as with the extra weight of the cable it may be causing it to jump back like that due to balance issues.
ok so it turns out my problem was caused by high frequency vibrations: despite having perfectly balanced props(statically and dynamically balanced that I have jello free video at the brightest light settings and when the gopro is hard mounted to the frame), the little high frequency sound vibrations that make it's way to the gimbal seemed to cause it to go crazy. What I tried today was to change the props to a different size(equally well balanced of course) and all of sudden I'm back in business.
@ohshme perhaps the reason you're all of a sudden experiencing issues is that something went out of balance and is causing some vibrations.
I too am still having issues with the video and it definitely was not working out of the box. I am still dealing with a slight up/down shake that is still there even when the motors are off and it is sitting on the ground. I am thinking I need to start looking at the tilt settings, but I am using the same settings as suggested earlier in the post that others are successfully using. This makes me think I either have a noise issue on the board itself causing this or a bad motor. Here is a video of the shake you can see. I slowed down the video to half speed to see the up down movement better. At the beginning you can see the shake on the ground and this is still apparent with the motors off. Next you can see the continuous shake. At this point I do not believe this is the mounting of the gimbal to my airframe, unbalanced props or settings. Anyone have any ideas based on their experience with this issue? I am going to check the settings again and rebalance props, but I might need to order a new motor and/or electronics to test my suspicions if this does not work.
the settings on page 1 and 2 (Gimbal controller and Motor controller) completely got rid of the jittering I was having. On boot with out the motors armed the tilt motor would vibrate pretty bad. If i moved it with my hand a bit it would stop but would randomly appear and disappear mid flight. Only did one test since changing the settings but no sign of it yet. Thanks again!!
My Tarot 2D gimbal had a slight tremor. Took advice and stuck a 12v BEC between my 4S and the gimbal and now it's rock steady.
