DucktileMedia
Tim, can you or someone else please explain to me how you can match the slow motion of a 60p camera with a 30p camera? Logically speaking, no matter how good each frame is, it is still only recording so many frames per second, right? So if you slow it down you will get the same glitchy-ness as you would with an ultra megapixel image sequence at the same FPS. On the GH2 you can up the bitrate substantially, but that is only decreasing the compression for each frame.I've heard this logic from others and i just dont get it.
As for what I was saying on the 5n compared to the TM900.....when i tried the TM900 and did a slow pan, the camera had a tendency to lock onto objects to help stabilize the image. This is great for when you are trying to hold still. And it was amazing even at a long zoom. BUT, for AV this has no place as you are always moving. When I tried it there was a noticeable jump when the tracking range left the screen. The Sony however had very good IS without any glitches or jumps. I should also mention that when I had the GH2 it had no issues with IS either, it was quite god as well. Furthermore I felt that this IS might be contributing to the super solid images I was getting from it.
Yuri
Yuri
