I changed back to( 8 )m3 hard rubber mounts and took out the wire loop style mount, i think the Cp like a firm mount. I'm have lowered the p on the pitch around a thousand point the buzz on the tilt is gone. I flew the other day and I still get micro vibration, I have spent some much time on this board and I have 2 of them. So what do I do now? I think it looked better with the wire loop but the pitch doesn't like it, I'm dooing my testing than filming,
First off, thanks for all the imput and help
I tried to adjust the roll to get rid of the buzz on pitch with a wireloop style dampnening plate with no luck, I adjusted the yaw and the buzz went away but now I get jumps in the yaw and instability of the yaw lose of posi in flight. Now I have 8 m3 hard rubber mounts and i get vibration in forward flight. When I used the wireloop I didn't get as much micro vibration in forward flight but the Cp board didn't like a softer mount. So what now, I think it's time for a glass of silver oak
No samur I havent - been having one prob after another - I suppose i prob should have sent support request earlier - will do that today. thought maybe someone here had seen this and easy fix -Did you send a support request?
Samur - FYI...I re-loaded firmware from GUI - before i did manually - after i got firmware installed, noticed the check box for "enable stabilization" unchecked for pitch - so checked it and all is good - not sure how i turned that off when i did firmware update manually - thought you'd wanna know - thanks for quick replyWhen you send a support request, we're seeing all the parameters of the gimbal this way and can solve your problem quickly. When doing that, put in the comment box ALL the problems you've been having.
i have the same problem. with the pitch down its buzz, i tried to lower the pitch and roll 10 percent at a time , nothing.I tried the yaw. took it down around -1500 from the stock autotune and it looks good on the bench, we will see in the air how it does.
