My brushless gimbal result
GotHeliRC
http://gothelirc.com
Kloner: I do have a bunch of .21mm wire, but I am not sure how to sell it... I have to check how much each motor, so no.. it does not for now.
Fixedwing: Yes, gimbal come with prewound motor, Kloner is asking about the motor kit.
is that at radio shack? so many turns in a patern?
Are you gonna have the prewound 4006 130 anyime soon?
aliche
Is it possible to mount the gimbal on the ground? I think its built to hang from a copter. so can i turn the arm that i could mount it up side down? does everything still works as it should?
Quad Head
Just pulled the trigger on one and a bunch of parts. Figured that if anybody deserves it you do. Can't wait till next week - like a kid at Christmas now!!
r0beert0
Hopefully will be able to finish everyone gimbal in 1-2 days after I come back. So the 19-21st....
Great! I should have one of these coming my way, looking forward to testing it out... this current servo driven gimbal I'm using is just not cutting it.
GotHeliRC
Smallest mini hdmi plug? :)
For those who are want to use the pancake lens .... I could not find any mini hdmi 90degree plug or adapter that's small enough. So you have to get the HyperThin cable and slice the rubber casing and metal casing off, cut or unsolder ground wire... re shrink it... now 1/3 of stock size. Fit with spare space left.
RC Flying
A Drone Mind
Cool, I'm having to do the same thing for a shutter control on my GH2, also right-angle but sticks out too much.
ovdt
GotHeliRC, I'm having hard time ordering this gimbal. I can't add it to the chart. I also wrote a PM about this; still waiting for your answer :)
Cheers.
vip
that re-wiring seems prone to problems, why not just build the gimbal a little wider..?????
Maverick
Would this do the trick ? I never saw it anywhere else, and thought maybe you missed it.....?
http://www.globe-flight.de/bilder/produkte/gross/FPV-HDMI-Konverter.jpg
http://www.globe-flight.de/HDMI-FPV-Converter
Sorry in advance for the noobish questions. I have a mikrokopter hexa with a worn out 2 axis servo gimbal. MK FC 2.1me board controls it. Can I use this gimbal and hook it up to my receiver so I can change roll/axis? Would it work stand alone hooked up to my receiver?
Sorry in advance for the noobish questions. I have a mikrokopter hexa with a worn out 2 axis servo gimbal. MK FC 2.1me board controls it. Can I use this gimbal and hook it up to my receiver so I can change roll/axis? Would it work stand alone hooked up to my receiver?[/QUOTE
Yes that will work ! Hook up the gimbal and the controller board for it to your RX, and keep the MK FC out of it.
If i understand it correctly you can also use the stabi from the MK FC, thus also use the control of pitch and roll that comes TX - RX - Mk FC. Question if you want that.
showatt.php
