As a newbie I nearly clicked buy based on your video alone.. Then I Googled the cinestar 6 to see its £7,000. I suspect this won't have hurt your video either so I'll delay for a bit longer!
Quality of the video produced with this gimbal has very little to do with the frame its flying under, I can show you plenty of videos I've done with the same frame and Photohigher AV130 gimbal that don't even come close to what this gimbal can do. I think next time I need to strap a GoPro to the frame itself so people can see just how much the frame is actually moving while the gimbal stays steady.
Now that I think of it, take a look at the very first test flight I did with it and you can see just how much the frame does move in relation to the gimbal, watch the front arm come in and out of the top of the video frame...
And that was taking a SWAG at the settings right off the bench, the other video is after getting it fully dialed in. As long as the multi can handle the weight of the camera and gimbal you will see pretty much the same results as long as you use rubber isolators between the frame and gimbal, true for any gimbal, not just brushless.
