UAVproducts
Formerly DJIUSA
Exactly, then you get into the whole weight of the props with effects on inertia etc..
Skyjib 8 / Good choice, be sure to get new center section and crash cage
DJI Wookong M / Or YS-X6
8x KW-8 PRO motors / Not sure if these are just rebadged Tiger motors (99% they are). Tiger motors usually have crappy bearings.
8x DJI 40A ESC's / No good. If you wanna buy now only CC ice with 4.01 firmware. If you wanna wait Herkules III is comming. Reflashed chinese esc's F60 if you feel lucky.
Av200 + 360 PAN RTU v2 / The freefly CS is a better gimbal. The AV200 should be retired.
PicLoc 3X Pro / The Freefly gimbal system looks promissing. The Picloc 3x is having some issues.
2x 5s 8000mAh / Maybe get more. You will need 2 at a time. (http://www.hobbyking.com/hobbyking/store/__16227__ZIPPY_Flightmax_8000mAh_5S1P_30C_.html)
JR 9503 + AR 8000 / If going for a WKm get Futaba with sbus.
Now some questions:
Frame and camera mount
For video work, how does the Cinestar + CS differ from Skyjib + AV200? Is the PicLoc gyro easy to tune?
Motors and ESC
- Have you tried KW-8 motors?
- Are the DJI ESC's any good? Are Maytech's better?
OR
- Is there any good reason to have a power board setup, for example Hercules? For the price of two I could get like three dozens of normal ESC's.. Also, if the board fails for any possible reason, I'd have to change the entire board. That sounds way too expensive.
Batteries
- I read that people use 2x 5S 11000mAh setups in these monsters but that sounds like a massive overkill.. What kind of flight times would I expect with 2x 5s 8000 batteries and a 5D onboard? Could I use even smaller batteries? 6-12 minutes
Props
APC? Graupner? What size? JXF 14x4 wood. (http://www.himodel.com/search.php?psearch=14x4) or 12x6 carbon fiber (http://www.foxtechfpv.com/1260-carbon-fiber-propeller-cwccw-p-522.html)
General questions
- What other accesories will I need?
- RX + camera mount battery (2s5000?)
- Regulators? CC bec x2
- Extension leads?
- etc. LED
I'd appreciate very much if someone could help me out with these questions! : )
Hey guys!
I'm planning to build a couple of heavy lifter octos some time this summer and I hope you could give me some advice! I've been flying normal helis for 7 years but multirotors are quite new to me. I have a Y6 Ardu at the moment but I need something bigger and more reliable. The idea is to carry a 5D or maybe even a RED Epic at some point. The heli should be perfect for both, stills and video. The idea is to have a helicopter that requires as little tweaking as possible and therefore I'd like to have a well optimized setup to start with. Here is the list of parts that I was considering:
Skyjib 8
DJI Wookong M
8x KW-8 PRO motors
8x DJI 40A ESC's
PicLoc 3X Pro
2x 5s 8000mAh
JR 9503 + AR 8000
Now some questions:
Motors and ESC
OR
Batteries
Props
General questions
- Regulators?
- Extension leads?
- etc.
Hey guys!
Skyjib 8
DJI Wookong M
8x KW-8 PRO motors
8x DJI 40A ESC's
PicLoc 3X Pro
2x 5s 8000mAh
JR 9503 + AR 8000
Now some questions:
Motors and ESC
OR
Batteries
Props
General questions
- Regulators?
- Extension leads?
- etc.
Thank you guys for your suggestions, but after reading some more I am going to go which Hobbywing platinium 40A or 60A ESC's... much cheaper and do exactly the same job!
Thank you for input.
The Plettenbergs seem to be very good motors but I have searched and searched again but can't find any shop that sells them. Where do you buy yours?
http://www.kopterworx.com/Accesories-Cinemastar/CS-Mount-3-axis-with-landing-gear
If I want to use this Cinestar gimbal on a Skyjib, will its own landing gear support the weight of the heli? Or will I have to use SkyJib retracks? Also the mounting seems to require an adapter which costs like hell (A friend of mine could probably CNC one)
How will the Hercules III differ from II? (Though I'm still unsure whether I want to spend 1000€ vs. a couple of hundred € for normal ESC's).
Would these be good ESC's?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11430
Are there any pre-reflashed ESC's available?
Hey guys!
Skyjib 8
DJI Wookong M
8x KW-8 PRO motors
8x DJI 40A ESC's
PicLoc 3X Pro
2x 5s 8000mAh
JR 9503 + AR 8000
Now some questions:
Motors and ESC
OR
Batteries
Props
General questions
- Regulators?
- Extension leads?
- etc.
and a skyjib is way to heavy IMO
