Hi gyroster,
I have had this problem also on one skyline, to solve it I have removed the belt and roll servo wheel and made the fine tuning myslef.
I first made the autotune and the autotune found 11258 for the roll value. after I made the fin tuning myslef I found something like -2540 or something like that.
You have to find the reverse point of the servo by changing the value with big steps (like 3000 or 5000) then you adjust it finely with the button until the servo don't move.
you replace the belts and make the autotune.
I will try to find another skyline with this problem and film it
Best regards,
Cédric
Hi Cedric,
I also do that. I'm not using a av130 or av 200 gimbal. My gimbal is a gear type. I remove the gear of the roll servo and tuning it till stops but from -5000 to 5000,still i can't find the motor to stop. i also remove the 2.4k dummy pot that i built but still no response. That is why i decided to firmware down to 1.1.7 from 1.2.2. Before upgrading to 1.2.2. i used 1.1.4 and the servo is responsive like 1.1.7 but experiencing jitter.
