Aeroxcraft Quad-670 - Now on Sale
£199.99 (GBP) - Shipping Worldwide
http://www.aeroxcraft.com/index.php?main_page=product_info&cPath=11&products_id=7
Designed primarily for use with the DJI Wookong M, the Aeroxcraft Quad-670 has a dedicated place for all the major WKM components. Under the dome the controller plate has places for the Main Controller, IMU, PMU and for your radio RX. On the rear of the frame is a place to mount your DJI GPS/Compass unit, with the ability to fine tune it's direction. Under the Quad, on the rear battery plate there is a mounting bracket for the DJI LED unit, which solves the problem of seeing the unit whilst in flight.
Not everyone wants to use the DJI WKM, luckily the Quad-670 will work with any other suitable multirotor controller. There is a custom mounting plate available for the Aeroquad Sheild 2.0. Contact us if you require this.
This quad was designed to compliment the Aeroxcraft GoPro Gimbal. The GoPro Gimbal sits right out front allowing your GoPro HD to take great footage without getting the Quad-670 in shot. The flight batteries are use to counter balance the weight of the camera allowing you to make sure the center of gravity is in the correct place.
The motor mounts will take motors up to 35mm in diameter, including Axi 2814/22 and Park480 1020kv.
There is a gimbal for compact cameras in development that will also be fully compatible with the Quad-670 multirotor.
Specifications:
670mm span (motor to motor)
G10 frame and aluminium booms.
All hardware included.
Includes:
* All hardware and fittings.
* A2 Stainless screws and nuts.
* CNC G10 and Aluminium frame parts
* Comprehensive Assembly instructions.
Example of a typical setup:
DJI Wookong M
E-flite Park 480 1020kv motors
Graupner Elektro Props - 11x5
2x ZIPPY Flightmax 4000mAh 3S1P 20C lipo batteries
GoPro Gimbal
All up weight including batteries and camera 2700g. Flight time 12 minutes.
Notes:
* Assembly required. Full instructions included.
* Gimbal not included, see gimbal product page.
* DOES NOT INCLUDE MOTORS, WIRING, ELECTRONICS OR RADIO
* Designed and Manufactured in the UK by AeroXcraft Ltd.
GOPRO, HERO are trademarks or registered trademarks of Woodman Labs, Inc. in the United States and other countries.
