I've gotten totaly lost in all this BEC talk and counter talk thing.  Zero issues here, never have been any with either of the two SXs I own.  For future reference, here's what I know and verified by ringing out the I/O box prior to ever installing either one:  The 5V center pins on the M1-M6 ports are dead-ended.  They go nowhere, they cross-tie to nothing.  Use a BEC bearing ESC, non BEC ESC, Opto ESC, whatever, matters not as the wires and hence, any 5V rail supplied by any ESC BEC, go nowhere, do nothing.  Makes sense, the FC runs off it's internal BEC supplied by the fight pack.  On the M7-M8 ports, the 5V rails *are* cross-tied to each other and to the "GB" port. (Gimbal Battery)  For folks using a servo-based gimbal system on a hex, this allows a single external BEC to be used to isolate the servo loads from the FC's internal BEC.  If you're flying an octo and using those ports for motors, best to float those two motor's 5V leads as the ESC's internal BECs may, or may, not like being cross tied to each other.  If your using optos, no issue as there's no internal BEC to start with.  Hope this helps if there's any remaining issues.
