Motopreserve
Thanks so much!
			Wouldn't it be nice to be able to read your own black box data locally?
I think sometimes XAircraft does things differently just to be different.
xAircraft, I believe many of your users would like an app to read our black box data. It's a pain in the rear end to have to get on the internet to look at our flight data.
Please!
Hey folks. Need a little help/clarification with tuning the SuperX. I have read the entire SuperX and black box manuals, read all of this thread and also corresponded with Anthony at Xaircraft. You'd think I'd get this by now...but noooooo
I'm either not understanding how the Tx rotary tuning adjustment (G) works, or it's simply not working (writing) after power down/power-up. As far as I understood it, I set the tuning in the software as a basic starting point - then make fine adjustments in the field with the rotary knob (channel #7 - G) on the Tx, which would be saved once I powered down.
So I do just that..
Basic settings in PC software: check!
Head out to the field and there is a horrible wobble. Turn the rotary knob up and it steadies: check!
Leave the rotary knob where it is, and power off the SuperX: check!
Put the rotary knob back to null point (thank god for beeps at center) before powering down the Tx: check!
My understanding is that this adjustment info would be written to the SuperX, and when I fired it up next, those fine adjustments would be written, and with the knob back at the null position, no new info should be going to the SuperX. Problem is: when I power the rig back up, take off, same EXACT wobble. Turn the rotary to the same exact location, and it's gone again. As if it's never been written to the FC....OR, I'm starring in the remake of Groundhog Day (...hmmm, wonder if Bill Murray has a quad...).
What am I doing wrong here???
Thanks for any light you can shed on this.
I'm using it with no problems. Once I set the knob, power down and power back up without touching the knob the attitude setting remains the same for the next flight until I touch the knob. Like everything else with this fc it's dumbed down but as far as I can tell it works as advertised.
The remote gain is labelled G in the inputs column. When you power down the FC the last setting is stored and is the starting point for your next flight. If you centre the control dial after you power the aircraft down it will not change the remote gain figure.
Are you saying I need to pull a servo before I power down? If so, I'm running sbus, so that throws a wrench in the works! The guy at xaircraft definitely described it the way I was doing it. But obviously something is amiss.
There was was a whole debate about whether there should be more features like the ones you describe. I'm one who prefers more features. If I can't use them - great, if not I'll ignore them. But at least the features it DOES have should be a little easier to use then this.![]()
so you are leaving the knob at the location you set at the precious flight - so it reads that as the same value the next flight. But it's not written????
That would mean, for all intent and purposes, that the adjustment is only by .1 values set in the software, and if you find the sweet spot using G adjustment, you just need to remember where to place the knob for the next flight? I can't see how that requires the use of powering up or down at all, if it's just the physical placement of an aux knob each flight.
This is the response I got from Xaircraft:
This led me to believe that I was doing the procedure correct (and without pulling any channels). Unfortunately, when I look at the log from 6 lift-offs today - despite doing the exact same procedure each time, the readings for G were: -26%, 106%, 106%, 0%, 0% and -8%. The only place I put the knob was about all the way up and back to zero.
Playing around with the gain settings, i was able to get -121 to 81+ with full sweep of the knob with weights set at 20%.
Endpoints or -20% to +20%.What are you referring to with "weights?"
i got got an email back from Anthony at xaircraft and he is wondering if my futaba is acting a little weird with the superx. Apparently they've discovered that the Taranis doesn't thing of zero the same as the superx does. More testing...
