I've plugged some numbers into eCalc and got some interesting results.
I had to use 'Custom' battery and ESC so i could enter more accurate weights (eCalc says a 4000mAh 3S 25C/30C is just over 110g - i couldn't even find one under 250g online!). The details i used were for the Zippy Compact 3S 4000mAh which weighs in at 286g according to HK.
I found that with any 9" prop, my flight times for 'mixed fight' were under 7 minutes with the battery as having a "full charge". Upping to a 10" x 3.8"pitch prop got me closer to 10 minutes 'mixed flight' timings, with additional capacity for payload. I took a screenshot of the eCalc page and posted it below for my best example setup using the Zippy Compact 3s 4000mAh battery above - what do you think, could i improve that by dropping to a lower capacity, and therefore lighter, battery?
