I have a Next Level 650 quad with the DJI Naza and GPS installed and functioning very well. I was out at the field performing a FPV flight last Friday when the incident occurred. Winds were calm with some small gusts. It was my first flight of the day. I took off and switched to GPS mode and started flying around. About a minute into the flight, the quad started to move violently back and forth left to right. I tried to correct it a few times but it didn’t make a difference then I lost video and it crashed to the ground but stayed upright. I looked at my gopro camera and it was flashing FULL on the LCD screen. I thought this was odd since the 16gb card was empty before I took off. Later I downloaded the video and the video cuts out before the violent left to right oscillations occurred. There was plenty of storage left on the card and the camera appears to be functioning fine. I have had many good flights with the current configuration and software settings. Current autopilot gains were set at 135% from the factory and that’s what I left them at.
Update, this happened again last night, no wind at all, it just fell from the sky oscillating all the way to the ground with motors still running. It hit the ground hard enough to break the landing gear but not hard enough to break anything else. The SD card was ejected upon impact. The video recorded up to right before the point the oscillations occurred. I can’t trust this DJI Naza system anymore until I figure out the problem. I might try turning off the battery monitor mode and see if I can get it to happen again.
Any thoughts?
Any thoughts?
