you just cut the pins in half to get it out and unsolder them with it apart. i've done that so it's super simple...... after burning a hole in my board within 3 minutes of powering it up
Can't believe with all your experience crashing is even in this post. how often you sending em in? what happens to make em do that? I haven't had a real crash yet, it'll be a year in about 20 days. i've had a battery fall off and unplug from 60 feet up, fell like a rock, had 2 batteries get high IR and LVC early on me, once into water. But other than that, i got nothin. Couple weeks ago i tried that rear mounted plug on a hero2 disco and it locked up the gyro or whatever, no damage but did hit a tree. Flipped over on the ground in glamis, but i wasn't even looking at it when i gave it throttle, was expecting to look over and see it in the sky, bent the prop adapters just enough to make jello. oh ya, that dragonlink ppm shift thing......... still didn't crash.
What r ya doin, 3d?
to use 2.4 in the us, you gotta hit channel 5 or 8........... 2300 band is pretty wide open at this point, forget which one i'm using, but it's crystal clear
