Totality, I had 5 FPV Flights right now with this setup:
Disco AUW 2110g
TM2216 900KV
10" Graups
30A DJI Optos
4000mah 4s
The Disco hovers at 50% Throttle, at WOT you`ll see an impressing ascent. Also after 7 minutes Flights alle the components where at ambient Temp.
With the added Weight and the 10" Graups the Disco flies like the 1600g Disco with the 9" Graups, the only difference i see is descending in M , that will be a lot faster
Recover from fast descends? No problem so far, really.
That Setup flies so sweet and easy that i'll give a try to add the Wide Angle Lens to the CX (another 200g)
So, go with the 2216 900s and your Disco will become a Killer Machine
cheers
meme
			I have 10" Graups (have been talking to Kloner) and was going to get the 800 instead of 900KVs as according to ECalc running 10" on the 900 2216 means they can go bang?  Are you saying they should be OK?  ECalc shows about 240W per motor at full speed and the motors are rated at 210W each for a TM2216-900.
All this motor stuff is confusing!!!  I was ready to just buy the 2216-800 and use 10" on 2KG AUW but from what you are saying it looks like it won't have enough power anyway, but then moving to 900KV means the motors are being put under too much stress according to ECalc!  Argh, what is right haha.
