I'll take that with a pinch of salt motop, I'm not army scum, I'm in the Royal Air Force and proud to serve!
Sent from my GT-I9305 using Tapatalk
No offense intended
No offense intended
Hmm, rather more difficult than I though this quad copter thing!
Attempted to dial in the pot gains this evening whilst I still had a bit of light left, result: 3 pairs broken props and a bent motor shaft or two. Now i have no props left and am trying to straighten the slightly bent shafts I two of the motors.
I think I'll speak with one of the guys who flies them at my club for a bit of help!
Pot gains I thought were the yaw, roll and pitch pots on the board?
I've not flown it at all before, so this was its first flight...
You have the KK5.5 board? Are you sure all your motors/props are the correct direction? Are you set up for X-Quad? That's a multiwii based board, no? Have you looked inside the sketch to make sure everything is set up well?
Describe what happened that caused the crash.
Well, that makes sense I guess. I would suggest keeping the quad facing away from you at first - especially in tight spots (like your yard). No need to add extra hassle to getting it tuned. Make sure you read that thread I linked (if you hadn't found it already). There were some people there that may have had issues with particular versions of the firmware. At least it might give you a heads up what to look out for. Seemed to be stabilization issues.
It was entirely my fault, and I really shouldn't have been trying to fly it in such a tight space. Add for the KK firmware, in running MinSoo Kims 2.9 Xcopter config. With the 4.7 firmware I had a lazy motor 4, even after esc calibration and end point adjustment in the board itself.
Very cool. I was taking the 4.7 from your first post. Seems people have issues, and you were one of them!
Good luck once you get the props back, and hopefully some more space to fly.
I have been doing testing in my driveway - with a garage on one side and very tall hedges on the other. Terrifying when the motors kick on - makes a space that SEEMED decent when it sat idling into the size of a thimble once the motors really spin up full speed....
New props arrived in the post, looks like another test flight could be on the cards this evening!
Thinking about maybe updating my fcb from the KK5.5 I'm currently running to this . Do any of you rate this flight controller at all, or should I look at the MultiWii Lite??
If anything, go with THIS:
of you're going Multiwii, it will be the easiest transition. This is a small board (physically) with all the pro options on it - and preflashed to fly. You can add GPS, and if you order the cables (cheap) you can plug straight in to the EZ connectors. If you want to get crazy - go for the black edition with the GPS/mag option. That one is wider.
Hi motop!
How does the board you linked compare to the various Crius boards? They're readily available here in the UK and from my untrained viewpoint look to offer more functionality for less dollar..?
