How do you to the triggering of the camera?
- What camera do you use?
- Is it via cable, servo or hack? (is it DIY cable or bought)
- What settings do you use on the camera?
- any tips?
thanks
I have two that I use for stills, a small Canon SX 200, and a Sony Nex 5N.
The Canon uses CHDK with an intervalometer script that will take shots at whatever I set for the interval and for as many shots as I want, all configurable parameters. Kind of a spray and pray method but since digital exposures are essentially free (as opposed to using film) it works fairly well. Get as many shots as you want and then just pick out the good ones, keep moving the multi around and varying the height to get shots from as many angles as flight time will allow.
For the Sony I use a GentLED connected to an unused channel on the TX and controlled by a 3 position switch. One position is off, and then there's a single shot mode on another and a continuous mode on the last. With an FPV cam and video downlink I can see very close to what the camera sees and line up single shots, or do like I do with the Canon and turn on continuous mode and just fly around.
Because of the ever changing light conditons when flying, especially if you change direction and angle a lot, I tend to use the built in automatic modes and then make any necessary adjustments in software after the fact. Gives me the greatest chance for getting decent shots from all angles without having to land and change camera settings as I would if I was using manual settings. If I really, really, really want to get the best shot possible then I'll use manual but it could take several tries to get it right, the light at ground level is not necessarily the same as it will be where the camera is in the air. If you do it enough you can develop a sense for what adjustments to make, I don't do a lot of stills so the auto mode works best for me.
Thanks Ken this is a very helpful piece.
For live view, do you use an extra small FPV cam lined up with the large cam? Or do you actually use the camera itself?
Sebas
Looking ahead, and to other possibilities, I wanted to ask what features you really use on a trigger, and perhaps what you wish were there?
Best
Esben
