Hey guys after a couple flights I have come to ask for help. I get decent flight through most of the stick but if im above about 80 i get a high speed shimmy you will see in the video. Gains are 120 120 145 140 atti 85 85.
I cant get rid of it , 4s 5000 dji 30 opto esc's apc sf 10x 4.7
http://www.youtube.com/watch?v=bt16Bl3DDZQ&feature=plcp
Get rid of the APC SF props they are crap on the QAV, Graupner 10 x 5 are much better, I was never able to get decent flight quality with the S/F set I have. I did manage to get an acceptable level of stability using the 9 x 6 APC thin electric props with Avroto motors and 4S 5000 battery. This is video of the first FPV flights of my QAV with the Avrotos and Graupner props, I've had a chance to make significant improvements since. I've seen 50 mph on the OSD display with a tailwind and close to full throttle, stable and controllable but things come up in the goggle screens awfully fast! Normal cruising speed is right around 30mph and slow is low to mid 20's, with the new motors and Graupner props it will still hit over 40 mph with ease...
I was using 30A ESCs reflashed with SimonK firmware at the time, I've since swapped to a set of 30A HK Blue/Maytech ESCs with stock firmware as the reflashed ESCs seemed to be getting hotter than I was comfortable with being stuffed close together between the lower frame plates. I also swappped the motors over to a set of 40mm 620KV pancake motors which has slowed it down a bit and helped stabilize the flight even further. The other thing is the QAV/Naza combo is very sensitive to gain settings and the CoG. I have both basic pitch and roll plus ATTI pitch and roll TX adjustable as calm vs windy needs to have both reset to keep the QAV smooth. I find that basic gains usually run 100 to 110% and ATTI 50 to 70%.
Of course none of that helped this past Saturday when this happened, you can see a hard vibration develop just before the end, and indication that something bad is about to happen...
Not sure exactly what caused it other than it was a problem with the left front motor. I almost managed to save it, had it within 20 to 30 feet of the ground, level, and trying to get it down as quickly as I could while I still had control but whatever the problem it happened again and down it went. With the amount of damage to the arms, motors, wiring, and props I'll never know for sure what the problem was, I can only speculate and that serves no useful purpose.
I already have it back in the air with some interesting modifications that seem to make it fly even smoother, more on that later...
