Gentlemen,
Just posting this as a reminder of the dangers of Lipos.
I sat down tonight to build a voltage regulated circuit to step down my 4s to 12 volts for my LED's.
I was using a breadboard to test the circuit. To set it up I initially used a zippy 2500mah 6.6v 2s with a nano tech 4s waiting in the background for the final test. The 2s was connected to the breadboard using a charger cable. It was a pre-made charger cable that came with my charger and appeared well made. When not working directly on the breadboard I disconnected one of the charger leads from the board.
What's frightening is that I'm still not sure what happened. I was engrossed measuring resistors with my multimeter and didn't notice the first plume of smoke until I heard the sizzle. I looked up to see the cable connecting the battery on fire and fast making it's way towards the battery. I grabed my snips and cut one of the battery leads to stop the short circuit then I immediately threw everything outside.
I'm still shaking ! The 2s battery was sitting directly on top of the 4s and I shudder to think what would have happened had they both caught fire. It was obviously a short circuit but I have no idea how it happened. I suspect one of my tools came into contact with it but for the life of me I can't figure out how. The fire started where the battery joined the cable. These are servo connectors so the battery cable was sitting snugly in the connector.
Anyway, just a reminder of the dangers ! I'm walking away from it for tonight. I'll finish the regulator tomorrow.
Eoin
Eoin
