the cable started out working great. Seems like when i put my ail/ele/throttle into the osdpro  to watch for missing frames and holds on the osd, it started doing this. The plug is aftermarket though,,,,,,,, and i drilled the case so it has to go through that as well, need to take a closer look at it
Use an ohm meter to make sure the assigned are going to the other end of the cable right and see if it's shorting? will do
