Kilby
Hi.
Here is the mix that did the trick with my Futaba FG8, but it should work the 10C as well. Ajust it while looking at the state screen in tx calibration in the assistant software until flipping the switch will cause Fail-safe (see state at the bottom of assistant screen) in EACH STATE (norm, atti, gps, course and home lock if you use it). When you flip the switch you should see blinking blue light in the led (along with red lights if GPS fix is not perfect).
Did it help you ?
Hi SharonX,
I was able to use your mix to get failsafe engaged while in one flight mode (gps in this case) but not the others. The mix doesn't seem to effect it when I have atti or manual mode enabled. Do I need to set up a different mix for those as well, or is there a way to get one mix to work with all 3 modes?
Thanks!
-Terry
