My Flight modes are programmed correctly in the Assistant. The LED has confirmed each of the flight modes when I operate it.
Yes, when I finished calibrating I finished with the arrow in the middle (green).
Okay... Let's review:
Manual mode: Everything works as it should
This indicates that everything is proper with my mixes and calibration. No concerns.
Attitude: After 55% Throttle - The motors ramp up to 100%. If I move the sticks between 100% and 60% there is no change in speed. They are maxed out. The LED does not indicate a failsafe.
GPS: After 55% Throttle - The motors ramp up to 100%. If I move the sticks between 100% and 60% there is no change in speed. They are maxed out. The LED does not indicate a failsafe.
I've checked and rechecked my mixes. There is no difference in my Mix between ID0, ID1 or ID2 (my three way switch) except the value of the mix used to change between the three different flight modes. There is no curves active and no trim active.
I've tried the default gains and the ones suggested above... same same.
I've tried this now with the GPS tower hooked up and without.
While it makes perfect sense that my remote could be at fault because it works in manual and there is no difference between the mixes between manual mode, atti or gps except the value... I'm starting to wonder if the Naza isn't working correctly?
