Tau Labs CC board on Carbon / Alloy frame
quadcopters
Hi Just built up a CC quad using .
500 Size Carbon Frame with Alloy arms. Cut down to 400mm Prop to Prop
Weight of frame at 500mm is 280g so very light.
http://www.quadcopters.co.uk/?PageID=ShowItem&Item=CA500&Desc=500%20Size%20Carbon%20And%20Aluminium%20Folding%20Frame
Keda 20-50s Motors
8" Gaui props 2 Green on the front.
Escs - 10a Hobbywing Pentium
Lipo 1500mah 3s 35c
Weight =507g without lipo.
Performance is awesome , Im Really loving this board .
Geoff Quadcopters Uk
Loks good Geoff.. them motors and esc' working ok then?
How easy was the CC board to set up? Did you do it on a PC or Mac?
quadcopters
The Board was very easy to set up , All done on my Mac .
Flies great with this motor and esc combo .
Made some adjustments and got it much more responsive , still tweaking it though :)
Geoff
Great to here the mac version has worked for you. I am sure the OP boys will be made up.
Any tips on the set up. Ill be starting my build this week when my motors turn up
quadcopters
A few tips , load correct firmware lol ,, Im supposed to be a veteran and being excited with the new board and using Spektrum gear I selected spektrum firmware so this meant the receiver being PWM was not recognised. It is for Spektrum satellite :) Silly me ..
So load correct firmware ... 2nd the stock settings are very tame but this is a awesome board , so turn up angle limits a bit at a time and inner loop to get it how you like it , I havent gone too far with settings , but once Angle limits tweaked and turned up inner loop I got it pretty much how I like it .
The GCS is very easy to use and well laid out and it is no suprise this board is out of stock everywhere.
Just hope they have some more soon as I have a Dex frame waiting for one .
Geoff
