LeeT
Wannabe AP Dude
Naza V1 w/GPS, 3.16 firmware.
Went to fly today and did my normal CSC, Bottom left, bottom right. The VU is flashing double yellow. I verify all my switches are in correct position, no trim, etc, and still can't get it to arm.
When I get home I hook it up to the assistant, and all of the controls are working as expected. Failsafe is not engaged. However, GPS is no longer is functioning. Through trial and error I get the motors to arm using CSC bottom left, bottom left. No other combination of CSC will arm the motors. When the motors are running, I still have a double orange blink on the VU until I get to 50% throttle. Then I get a single orange blink.
I had a crash a while back, and had to replace two motors. After I installed the new motors I did a bench test and everything was fine. Also I did a test flight (mostly hover) in my yard, and no issues. Flew in atti and GPSX mode with the GPS holding relatively solid. Everything was as expected in the assistant including IOC, and GPS showing up as flight mode.
The only thing I can think of is the naza is fried and I need a new FC. The V2 is hellatiously expensive especially if your not going to use most of the features, and I'd rather not go on the hook for $420 if I can avoid it.
Any suggestions?
Thanks,
Any suggestions?
Thanks,
