Welcome To DroneVibes
A2 receiver vs external. What are you using and why?
Discussion in 'DJI A2 & WKM flight control systems' started by Pumpkinguy, Mar 8, 2015.
  1. Pumpkinguy
    Pumpkinguy Member
    967
    185
    26
    Sep 20, 2014
    Toronto
    Posted by Pumpkinguy, Mar 8, 2015 #1
    I do have a 7008sb reciever but I'm thinking I will use the built in reciever as this eliminates a connection and an additional failure point. The down side is I cannot use voltage telemetry to my 14sg. What are you guys using and why? Pros and cons? Thanks.
    Tags:
  2. Carapau
    Carapau Tek care, lambs ont road, MRF Moderator
    1,035
    162
    46
    Jan 19, 2013
    N Yorks
    Posted by Carapau, Mar 9, 2015 #2
    I use a Jeti plugged in via the DJI sbus converter. Works a treat. No disadvantages from what I can see, big advantage is that it is allowing me to use the best TX out there (in my opinion of course- others will clearly disagree!)
    2 people like this.
  3. Bartman
    Bartman Welcome to MultiRotorForums.com!!
    8,439
    709
    116
    Jan 5, 2011
    New Jersey, USA
    Posted by Bartman, Mar 9, 2015 #3
    using a Futaba S-Bus converter with a JR receiver.
    haven't flown it much due to the weather but did it so i could have discreet wired inputs to a receiver for a dual receiver system i use
  4. Pumpkinguy
    Pumpkinguy Member
    967
    185
    26
    Sep 20, 2014
    Toronto
    Posted by Pumpkinguy, Mar 9, 2015 #4
    I've seen those but don't know anyone that has one. They look awesome though
  5. Pumpkinguy
    Pumpkinguy Member
    967
    185
    26
    Sep 20, 2014
    Toronto
    Posted by Pumpkinguy, Mar 9, 2015 #5
    Is this for your one man/two man setup?
  6. Bartman
    8,439
    709
    116
    Jan 5, 2011
    New Jersey, USA
    Posted by Bartman, Mar 9, 2015 #6
    yes
    might get to test it this week if the weather continues to improve
    2 people like this.
  7. SleepyC
    SleepyC www.AirHeadMedia.com
    1,709
    342
    66
    Posted by SleepyC, Mar 9, 2015 #7
    I use the onboard Futaba REC. No issues at all, and my cam op uses a Sbus rec into the Zenmuse... perfect combo, less stuff on the copter.
    2 people like this.
  8. rilot
    rilot Member
    298
    2
    0
    Aug 18, 2013
    Posted by rilot, Mar 10, 2015 #8
    FrSky X8R receiver via S-Bus in to the A2. I do it this way because I use and love the Taranis' programmability.
  9. fltundra
    fltundra Member
    830
    77
    11
    Mar 13, 2014
    Key Largo, FL
    Posted by fltundra, Mar 10, 2015 #9
    You can bind the Frsky X8R to use S-bus on ch 1-8 and 9-16 for gimbal and accessories. Then use a 2nd taranis for 2 man op with second PPM D4R receiver connected to the trainer port.
  10. Pumpkinguy
    Pumpkinguy Member
    967
    185
    26
    Sep 20, 2014
    Toronto
    Posted by Pumpkinguy, Mar 10, 2015 #10
    So only one vote so far for built in. Wow. I would like to have that voltage telementry.
  11. SleepyC
    1,709
    342
    66
    Posted by SleepyC, Mar 10, 2015 #11
    I know 5 guys using the built in REC with NO issues. Also the intelligent landing gear rules.
    2 people like this.
  12. Pumpkinguy
    Pumpkinguy Member
    967
    185
    26
    Sep 20, 2014
    Toronto
    Posted by Pumpkinguy, Mar 11, 2015 #12
    Ok. 5-4. Lol.
  13. Carapau
    1,035
    162
    46
    Jan 19, 2013
    N Yorks
    Posted by Carapau, Mar 11, 2015 #13
    I wouldn't worry about using either an external receiver or the in built one. There have been so few reports of A2 caused crashes for some time now and a whole shed load of them in use that I suspect that either option is proving to be pretty robust (hopefully those aren't famous last words!). I would chose external vrs internal based on the transmitter you are happy using.
  14. Pumpkinguy
    Pumpkinguy Member
    967
    185
    26
    Sep 20, 2014
    Toronto
    Posted by Pumpkinguy, Mar 12, 2015 #14
  15. Tahoe Ed
    Tahoe Ed Active Member
    2,064
    27
    31
    Sep 14, 2011
    Posted by Tahoe Ed, Mar 19, 2015 #15
    I use the lightbridge vs the internal Rx. More distance and HD video downlink and I have telemetry.
  16. Pumpkinguy
    Pumpkinguy Member
    967
    185
    26
    Sep 20, 2014
    Toronto
    Posted by Pumpkinguy, Mar 19, 2015 #16
    Useless In my case with the Gremsy gimbal (no slip rings). But I am considering using the LB for video only. I know a few guys that either use this or have tried it. No problems with interference with other 2.4 equipment.
  17. glmccready
    glmccready Member
    15
    4
    0
    May 26, 2014
    Posted by glmccready, Mar 20, 2015 #17
    Since I have a Graupner MX-20 for my Mikrokopters I just used PPM from a Graupner Rx. Added a Telemetry module for 2s-14s. I like Graupner for the Voltage telemetry and the flight info stored on the Transmitter (SD), not just the iOSD data, which seems a bit flaky.
  18. snurre
    snurre Member
    215
    4
    1
    Apr 12, 2012
    Stockholm, Sweden
    Posted by snurre, Mar 23, 2015 #18
    FrSky X8R and Taranis plus as TX. Wonderful programming options, Failsafe options, good telemetry with logging, RSSI and S/bus output to the A2. And 8 ordinary servo output ports (CH 9-16).
    I decided against "intelligent landing gear". I must be able to fly really close to ground, below 5 meters, with the gear still up.
    I have a LB that will probably be used for video only, if FrSky RC link works stable with LB in use.
  19. Carapau
    1,035
    162
    46
    Jan 19, 2013
    N Yorks
    Posted by Carapau, Mar 25, 2015 #19
    You can do that with the A2 still even with intelligent gear sellected. You do need to go above 5m off the ground initially to raise the gear but once that is done the gear will stay up unless there is a 'go home' event or if you select gear down. The gear will stay up otherwise even if skimming the grass!
  20. snurre
    snurre Member
    215
    4
    1
    Apr 12, 2012
    Stockholm, Sweden
    Posted by snurre, Mar 25, 2015 #20
    This is good to know. Thanks!
Loading...
Share This Page
Loading...
