throttlejockey
Looks like a couple things going on.  I think you may need to soften up your sticks a bit. Perhaps without knowing your main roll servo is too sensitive to small adjustments causing the gimbal to have latency relative to the gimbal roll axis.  You may want to speed up (increase) the gimbal roll compensation servo on your gimbal. I have similar Roll axis issues when I am using the 3 axis especially causing that jerky thing. It could be the torque that moves the copter during the initiation of pan and it's causing me to make quick roll adjustments to the copter resulting in the gimbal not keeping the cam level and smooth.  I'm fiddling with higher value's on the gimbal servo compensation values to try to eliminate one of the several variables.
Other thought is to check your belts and make sure they are nice and tight. Finally, check your CG with and without the cam and make sure all is level prior to flying the cam. I'll keep you posted as I work through the same issues.
