Installed on my OCTOCOPTER the following  equipment and electrónics:
Frame: KRAKEN 130 FOXTECH
Motors: Avroto LIFT 3520 400Kv
ESC: FLYFUN 60 A HOBBYWING
<tbody>
</tbody>
Flight Controller: DJI A2 + iOSD II
Propellers: Carbon 1855
GIMBAL: EAGLE EYE BLG5D DSLR BL (FOXTECH)
Gimbal an Camera Control: FUTABA 10 CHG
CAMERA: CANON 5D MARK II
FPV Transmitter: FPV584F Plug and Play 5.8 GHz 400mW
Flight control Transmitter: FUTABA 14 SG
The purpose of the OCTOCOPTER is aerial photography with a CANON 5D MARK II.
I made 14 successful flights from April to July without the gimbal and the camera, but on July 23 in test flight with Gimbal and the camera, the OCTOCOPTER lost all power and fell from a height of 19 meters with serious damage to the CANON camera, GIMBAL and OCTOCOPTER.
I am evaluating the cost of equipment lost in the accident and at first estimated to be around usd $ 5,000.
I dowload the flight information from IOSD in which can see a sudden cut off of power to the motors. Would like to have a diagnose of the problem, because have to decide what to do to repair my equipment.
| PARAMETER | OPTIONS | SETTING | |||
| BRAKE | OFF | ON | OFF | ||
| BATTERY TYPE | Li-xx | Ni-xx | Li-xx | ||
| Cut Off Type | Soft-cut | Cut-off | Soft-cut | ||
| Cut Off Voltage | Low | Medium | High | Medium | |
| Start Mode | Normal | Soft | Very Soft | Normal | |
| Timing | Low | Middle | High | Low | |
| Music Li-Po Cells | D | C | B | A | NONE |
| Reserved Item | Option 1 | Option 2 | Option 1 |
<tbody>
</tbody>
