The full specs for the Crius AIO PRO V2 version are (copied of the website):
ALL IN ONE PRO SPECIFICATIONS
Supported MegaPirateNG (arducopter) and MultiWii firmware
Up to 8-axis motor output
8 input channels for standard receiver
4 serial ports for debug/Bluetooth Module/OSD/GPS/telemetry
2 servos output for PITCH and ROLL gimbal system
1 servo output to trigger a camera button
6 Analog output for extend device
A I2C port for extend sensor or device
Separate 3.3V and 5V LDO voltage regulator
ATMega 2560 Microcontroller
MPU6050 6 axis gyro/accel with Motion Processing Unit
HMC5883L 3-axis digital magnetometer
MS5611-01BA01 highprecision altimeter
FT232RQ USB-UART chip and Micro USB receptacle
On board logic level converter
Dimension: 50mmX50mm
Height: 11.6mm
Weight: 14.2g
hole spacing: 45mm
Hole diameter: 3mm
Sent from my GT-I9305 using Tapatalk
Height: 11.6mm
Weight: 14.2g
hole spacing: 45mm
Hole diameter: 3mm
