So.. all my TX kit is Spektrum.
I cant seem to get the A2 to see the Satellite receiver. I have bound it to a AR8000 as DSM2 at both 11 and 22ms frame rates but no joy. The assistant just does not see the satellite..
Any one got it up and running on Spektrum?
Is this because of an upgrade,?
I have Dx8 and nazza V1 and never had problems,Ar8000.and Tm1000.
Mine works flawlessly with my Futaba but I wanted the option to use my JR9503. Unfortunately I only have a single DSM2 so I tried the DSMX and got no connection. I ordered 2 new DSM2 and will have them by Thursday to see if they will bind. After that I do not know what to do.
I got my A2 connected to my DSM2 Satellites. You have to connect to Assistant via usb, do not connect the lipo. Set to DSM2 in Assistant and then do the bind. Make sure that you watch the channel mapping. Set your channels in your Tx to normal. Then adjust them in Assistant. I am using a JR9503 and T, A, E, R, U are set up for channels 1-5 in that order. Check in Assistant that they are moving accordingly. I mapped U, the Gear channel to Flaps, that way it mirrors the rest of my set ups. My IOC is on Aux2 and unfortunately I was only able to map the RTH to the right slider. This is not a DJI issue but a limitation of my Tx. If you have a DX18 you may have more options.
Dave ...
Try KingsLynn Model Shop
http://www.kingslynnmodelshop.co.uk...eivers-Spektrum/c29_100_315/index.html?page=2
seems like they have DSM2 satellites but you need to make sure.
andy
Dave,
I think that right now I am getting 7, however, I think that I could get one more. Right now I cannot get Aux 1 to work.
