Windows 10 naza assistant no worky
Pumpkinguy
I just built a 350 sized armattan quad as a trainer. Something that will take a shite kicking.
Naza V2..... Tmotor 920kv and 20A air escs.
Got her all done. Downloaded dji windriver then Naza V2 assistant.
I have been working at this an hour. Cant get the assistant to see the naza. She appears to be working. I am getting satillites.
Tried 3 different dji usb cables.
I only have 1 pc in my house. Windows 10 so cant even try on another pc.
Pumpkinguy
Pic
Pumpkinguy
ok. problem solved. I needed to have my naza powered up and plugged in while I installed the win driver. lol
Last problem. throttle is the same from the stick in the fully down to the center point. idle speed. then from center to top it takes off like a mofo. makes it impossible to have a smooth take off. Endpoints on my futaba 135 100 100 135 just5 like my other setups.
all esc's were throttle calibrate to the futaba.
Hexacrafter
Manufacturer
Pumpkin,
This is the way NAZA V2 acts on take off. It was intentionally done as a take off helper for novice flyers.
I complained about it when V2 was first released, even posted on MRF....
Some like it some hate it....
I requested that DJI allow the users to chose it as a setting...... No Responses!!!
If you quickly get over 50% and then drop below 50% and then raise again you get "NORMAL" throttle control.....
I have one NAZA V2 left on a demo aircraft, but am not a real fan of the V2....
