What battery with this setup
ChEB
about to order a Tarot FY650 to carry my gopro 3 from helipad however I have no idea which battery to select. This is the part that makes me think im in over my head. I'm also hopping this setup will work? Was hopping for 5 to 10 mins of flight time. I'm guess that I need a 22.2v 5000mah 3S and if thats the case I could use some recommendations.
4 Storm AS-2216 motor (880kv)
10" carbon fiber props
DJI Nava-M V2 multirotor Gyro System w/gps
hobbywing 30A OPTO pro ESC
Walkera Devo RX701 2.4Ghz 7ch Receiver
Boscam 5.8 ghz FPV TS352 tx
sony 700TV lines CCD Camera
Tarot T-2D Brushless Gimbal
jbrumberg
Recommended Configuration 1: gopro configuration (recommended)
180-250W Motor +20 A ESC the +4 S 5000 battery +10-12 inch propeller
Recommended configuration: micro single configuration (generally recommended)
300-400W Motor +30 A ESC the +4 S 5000-10000 battery +12-14 inch propeller
Recommended configuration: SLR configuration (not recommended)
400W motor +40 A ESC +6 S 5000-10000 battery +14-17 inch propeller
I copied this from a thread pertaining to your model Tarot frame from rcgroups.com. Have you run your setup through eCalc?
PeteDee
Mr take no prisoners!
On that frame and the weight you are planning those motors are only just powerful enough.
You will need a 30C 4S pack, 5,000mH would be a good size I think.
Pete
ChEB
haven't found an eCalc yet (working on a slow satellite internet connection until i get back home)
ChEB
Pete
after continued research I agree. I'm now going with turnigy multistar 4822-690Kv motors and 12" props
