Hey guys, first post only cause I have a wild problem occurring with my setup. It's a qav250 running the full naze32 fc, afro mini 12a esc with Simon k pre flashed, 4s battery, spektrum ar610 rx with dx6 tx, and lumenier 1806 2300kv motors with gemfan 5x4's. Not sure how relevant any of that is for this problem but just putting it out there.
Ok so here's the issue: the motors hit what seems like full throttle, at only half stick on the tx. In baseflight the throttle channel and motor test boxes continue to read from 1400 up to 1980 but the motors don't spin up any faster. I've tied everything from calibrating all 4 esc at once in baseflight, calibrating them 1 by 1 directly thru the rx, setting min and max in the cli, setting the tx to try and get mid power at mid stick, and 1 by 1 via motor test. Nothing changed a single thing other than when I calibrated 1 by 1 in motor test, they got slightly better, as in the motors worked exactly as they should, but only 2 of them. The other 2 actually got worse and didn't even turn on untill around 13-1400. Both my friend, who knows much more about this stuff then I do, and I are stumped and any ideas from people would be great. At this point he's thinking something is wrong in the latest firmware for the naze or the Simon k firmware. I managed to bandaid the problem by setting my throttle curve via the tx, but it's almost completely horizontal, and now the fc only reads throttle input up to 1300 which for the motors is full throttle. Here are my throttle curve points:
1: 0%
2: 9%
3: 11%
4: 15%
5: 18%
6: 25%
7:----
Not sure if this is normal for mini quads or not, but it doesn't seem right to me. Any help is appreciated!
1: 0%
2: 9%
3: 11%
4: 15%
5: 18%
6: 25%
7:----
