Welcome To DroneVibes
Video Transmitter
Discussion in 'Recreational sUAS Flyers Discussions' started by Idahobell, May 14, 2014.
  1. Idahobell
    Idahobell Banned
    109
    1
    0
    Mar 14, 2014
    Boise, ID
    Posted by Idahobell, May 14, 2014 #1
    I have a Tarot 680pro with the GoPro Hero3+, Boscam 600mw 5km Tranmitter and Lilliput 329DW but my video reception sucks. The video breaks up at around 100 meters and I lose it all together shortly after that. Anybody have any suggestions for a better FPV set up with longer range?
    Tags:
  2. RichardDoty
    RichardDoty Member
    80
    0
    0
    Mar 19, 2014
    Posted by RichardDoty, May 15, 2014 #2
  3. PeteDee
    PeteDee Mr take no prisoners!
    1,369
    14
    21
    Mar 13, 2013
    Dot
    Posted by PeteDee, May 15, 2014 #3
    Are you sure the vTx and vRx are on the same band, should be getting over a km with that setup.
    What antenna's are you using?
    Pete
  4. Benjamin Kenobi
    Benjamin Kenobi Easy? You call that easy?
    2,179
    70
    31
    Jun 22, 2012
    The Cotswolds, England
    Posted by Benjamin Kenobi, May 15, 2014 #4
    As Pete says, what antennas are you using?
  5. PeteDee
    1,369
    14
    21
    Mar 13, 2013
    Dot
    Posted by PeteDee, May 15, 2014 #5
    And have you accidentally run the vTx with no antenna, that will surely kill a 600mW vTx.
    Pete
  6. Idahobell
    Idahobell Banned
    109
    1
    0
    Mar 14, 2014
    Boise, ID
    Posted by Idahobell, May 15, 2014 #6
    It has the two antennas on the monitor that came with it and the single antenna that came with the transmitter. They are both on the same band. I just replaced the antennas on the monitor to the mushroom type but not anybody better.
  7. cootertwo
    cootertwo Member
    746
    117
    26
    Oct 29, 2013
    oii0i0i
    Posted by cootertwo, May 15, 2014 #7
    "AND" the antenna type. Some have a male pin, some don't SMA, RPSMA
  8. Benjamin Kenobi
    2,179
    70
    31
    Jun 22, 2012
    Posted by Benjamin Kenobi, May 16, 2014 #8
    Alas those 'single' antennas are the worst. They are called 'rubber duckies' and have very limited range. You really want skew planter and clover leaf type antennas as a minimum. A small patch antenna on your receiver will quadruple your range. Try one of the 'mushroom' antennas on your transmitter (aircraft), that should help a bit.
    Hope this helps. :nevreness:
  9. Joely-Bird
    Joely-Bird Member
    28
    0
    0
    Jul 19, 2013
    London
    Posted by Joely-Bird, May 16, 2014 #9
    I'm about to face similar issues, I'm in the process of adding FPV to my quad, is one Antenna type compatible with another, (can you transmit from cloverleaf & receive on patch, or do they have to match?) what have people found to be the best combo or matched type?
Loading...
Share This Page
Loading...
