JaymzShikari
Hello, part of the reason for me building my quad was to assist with my college application for an electrical engineering course. It's "an optional pre-entry project at your(my) own cost to help the college assess your(my) current practical and theoretical knowledge." - quote from the lecturer.
I essentially had to build something that took some electrical knowledge and produce an instructional video of me building it and an instruction manual so that someone with the exact same parts and tools as me could build it to a high standard with no previous knowledge.
I submitted my completed quad (configuration listed below) and the lecturer was very happy with it. Now for the second part of the project I'm a little stuck, he has given me two common adaptations I have to make (again with instructional videos and literature). He would like me to find a way to make the whole system more efficient and find alternative power sources. I still have to use batteries I just have to make them more "user friendly" as the lecturer believes that LiPo batteries are "too dangerous" for people uneducated on the topic to use, despite the fact it's actually relatively simple to look after them.
Anyway, what I thought for making the project more efficient was to switch to a lighter frame, possibly carbon fibre, I have found some motors which are lighter and more efficient and I have found a lighter LiPo. I feel that that will be enough to create a notable increase in efficiency (If you have any other ideas or criticisms of this please tell me as I would like this to work as well as possible.)
As for the more user friendly I thought of using 1.5V Ni-Mh AA 2900 mAh rechargeable cells as I came across 16 of those lying around in my room. My thoughts were I could create 2 batteries by running 8 in series to create 2 12V Ni-Mh 2900 mAh batteries then running those two in parallel to each other to create a 12V Ni-Mh 5800 mAh battery. I've done my research on setting this up and I think it will weigh around the same as my 11.1V 2650 mAh LiPo fully set up so it would add no extra payload to the quad if I was to add just one of the batteries.
My question is: Have I overlooked something important with this idea? I feel that I have otherwise other people would have used this method to power their budget quads as it appears to be cheaper, lighter and higher capacity than a budget LiPo.
Also while I'm here I may as well post my other question, I have bought LED strip lighting for my quad so I can fly by night (as the only open field near me is also used as a footpath by a high school full of pre-adolescents that like to surround me and get in my way whilst I'm trying to fly). I would like to wire them in in the simplest way possible and I think I've devised a method of doing it without having to dismantle my quad and trying to solder over other connections I've already soldered. My ESCs aren't soldered directly to the power distribution board as I decided to solder short cables with bullet connectors onto the board and connect the ESCs in that way so I can take the set up apart and reassemble it easily. I have some spare wiring and bullet connectors, would I be able to make splitters to connect to the +ve and -ve outputs on the board meant for the ESCs and connect my lighting to those? So the LEDs on each arm of the quad are powered seperatley to each other and aren't all on one circuit? I realise that I am making this more complicated than it needs to be but I think it will be more practical for me in the long run.
Thanks for the help and sorry for boring you all to death with my life story. I'm Jaymz by the way.
EDIT: I forgot to include my setup
Frame - DJI F450
Motors - AGM 2213 935 kV
ESCs - Hobby King 15-18A
Control Board - HK KK 2.1
LiPo - Power Poly 20c 3s - 2650mAh + a low voltage alarm
Rx - OrangeRx R615
Tx - Spektrum DX4e
Frame - DJI F450
Rx - OrangeRx R615
Tx - Spektrum DX4e
