TBS Discovery Pro OSD
PeteDee
Mr take no prisoners!
And that Bruce is what is usually the problem, if they are set correctly then you probably have a faulty Core, they are pretty much bulletproof so they either work if set up correctly or they are faulty.
billmac
Thanks guys have tried it in Pall and Ntsc without any success so if it is the core should I send it back to the store I got it from this would be major pain in the ***. Mind you the hole TBS thing has been a pain in the ***.</SPAN></SPAN>
that monitor should have several pal and ntsc modes, go through them all..... it's in the monitors setup screen. I've seen a similar look on a rig that had extreme hoping on the ezuhf enabled, that on by chance or dragonlink?
billmac
Hi Kloner
thanks for the reply however not sure what you mean(several pal and ntsc modes) I think its the core as I cannot see the OSD on the TBS69 its the Pro
so the core was already installed with the shield.
PeteDee
From that photo I can see the OSD is working, there is a mismatch on the sync though. You could just make up a lead and run the camera directly into the vTx to eliminate the Core and make sure everything else is working.
Pete
