Things I have done
Calibrated sticks in tx
Calibrated sticks in software (They move correctly)
Selected hexa v in the software
Calibrated imu basic in software
Calibrated imu advanced in software
Reloaded 4,02 firmware (While connected to pc)
Reloaded Win divers (While connected to pc)
Reset end points: Low end -116 High end: +116 then re-calibrated esc and all 6 calibrated and had a linear throttle at the end of calibration
De-soldered all motor wires and remake all the motor wire connectons
Motor leads from motors are plugged into then motor side of the naza with the white wire (signal) to the top. Servo leads from the other side of the naza plugged into naza with the light colored wire (signal) to the bottom, The other end of the servo leads are plugged into the rx with the light colored wire (signal) to the top.
The same radio setup I use now on the Taranis is the same setup I used on my quad. Except now its a hexa.
ESC: DYS 40A
Motors: DYS BE4108 580Kv 821W
Tarani tx
X8R rx
And right now I can't think of a thing I have left undone.
I think there is something about these esc's that the nzaz v2 does not like and it might be the timing. Even though they all will calibrate and spin up with a liner throttle.
ESC: DYS 40A
Tarani tx
X8R rx
