Hi everyone, I'm pretty sure this is one of my first couple posts here so I hope it's a helpful one!
While doing plenty of reading Across the internet I've noticed many people are complaining of issues with the XA electronics. I wanted to share my experience with it considering I either got really lucky or I did something different in the setup...but so far mine has been flawless. Now, to be completely honest in the beginning when I first put it together following the instructions exactly, I did find a little instability issue and a problem with holding attitude. After speaking with Jeffrey (extremely helpful guy, and I will be purchasing from him again) he pointed out to make sure all wiring is as far away from the compass as possible and not to let any wires pass over the top of it.
I went back to the drawing board and noticed that there was some extra hardware that the kit came with including some longer standoffs for mounting the flight controller and an extra mounting plate. I use these to get the compass up higher and out of the way. The next thing I did was spend a decent amount of time leveling the frame with a bubble level for the calibration with the software. There's also a compass calibration in the software that I feel is pretty critical to get this to perform correctly. I used a lazy Susan to calibrate it by placing the chopper on it so I could spin it concentric in both flat and on its side. Leveling the booms/motors was also important in the set up process.
The chopper flies rock solid, holds heading perfect, and the return to home function works great. When I'm running the GoPro and Gimble I fly the chopper heavy at about 2350 grams with two 4000mah Hyperion 3cells. I get almost 14 minutes max with this setup. One other thing I found was that by sliding the batteries and camera gimble closer together towards the center point of the aircraft alleviated any extra rocking when going from forward or reverse movement to a hover...this also resulted in nicer video footage.
Anyway, just wanted to drop my setup on you with some photos.
View attachment 6066View attachment 6067View attachment 6065
