Av8Chuck
I have a Hex with:
Avroto 2814 motors
Graupner 12" E-Props
RCTimer 30A ESC's
NAZA w/GPS
5800mAh 4S batteries
After solving an issue with arming I took it out for its maiden flight. Took off in Atti mode after liftoff and increasing the throttle to about 65% I started getting a flasshing red LED and a couple of seconds later it landed. Nice to see that it worked. Switched to Manual and it took off and flew fine, however, since I had a flashing red LED I decided to take it home and check into why this was happening. I checked the battery and it still had 80% left, I have not re-charged it to see how much it takes.
In the Voltage Monitoring setup of the Assistant I just chose 4s in the drop down menu and left everything else as it was. What numbers should go in there and how do you figure it out?
[h=2][/h]
Avroto 2814 motors
RCTimer 30A ESC's
NAZA w/GPS
[h=2][/h]
