Hi Guys
I am still plugging away at my camera mount system and need some information on modifying servos for use with external pots.
I see all the High end camera mounts use modified servos. Photohigher and teh AV130-200 and the new cinestar mount plus a few others.
Please can you point me in the right direction so i can find info about how to do this mod and where to find the correct Pots.
Just to make sur eim not missing anything, the main reason to modify the servo and place teh Pot in teh axis of teh actual part of the mount to be moved is so that the sercos travel is no longer limited?
Correct?
We are basically fooling the servo to into thinking its only moved 90 degrees (or what ever) when in actual fact, due to teh gear ratios used its moved maybe 180 degrees.
If this is the case cant we simply relocate the original pot from inside the servo to the new axis??
My new camera gimbal would require about 120-150 degrees rotation on the pitch axis and with a gear ratio of 50:1 i would need to get upto 300 degrees of rotation from the servo correct?
Im planning on using my Hyperion DS20FMD's that I have on the shelf.
Cheers
Ben
Correct?
Cheers
Ben
