Good luck tomorrow testing. My Z is set to -9cm on both the 450 and 550. I think it is supposed to be to the CG in other words if you have a lot of low weight it would be lower. I have tried various settings but on my helis it does not seem to make any difference. They are about equally stable even though the 550 with gimble and cam is probably a few cm lower CG.
Here is a video of my F450 flight today, it was all done in Atti mode except for when I show the TX, it held GPS pretty good there for a while:
Lousy weather here. Low clouds but it is warm. The mist is the snow we should be skiing on.
This is raw footage shot with a GoProHero2 mounted under an F450 with dampeners from McMaster Carr No gimbal, I use the medium lens setting, I don't like the wide distorted view, I know you can fix it in post. I use an iPhone to control the GoPro, and it does give you a 3-4 second lagged FPV view. My father 84 was watching the iPhone and got dizzy.
The 450 is very responsive, this was pretty close quarters, definitely an IFR day here. Easy to loose sight and orientation of the heli in the mist.
Thanks. I need a new prop so earliest ill be able to test is probably Wednesday or Thursday.
I don't see the video?
