Scarab Multiwiicopter FPV Aerial videography
Dear all,
I am creating this thread to post my videos. I have several aircrafts, all from multiwiicopter.com , one Y6, one QuadOcta and one Quad Reconn. The fpv setup is based on hobbywireless 900mhz, Sony SN777 and/or Gopro HD2. RC is either Futaba with telemetry or Thomas Scherrer Long Range System.
Here is one of my babies:
To start, here is one of my preferred videos, in Bordeaux vineyard:
https://vimeo.com/43745851
Gregory
T-Rex 550 FB
FPV : Scarab Multiwiicopter QuadOcta & YSiix
Nice video. Could have done without the watermark, however.
Jack
Thanks.
Regarding the comment on the watermark, I disagree:
First, some people may not be transparent and "promote" equipment without informing that they are linked to it. I prefer to be 100% transparent.
Second, nowadays most of the newbies think that they can achieve semi-pro videos with a $30 airframe. Then a company like multiwiicopter struggle with the customers that do not understand why they should pay more for a full carbon airframe that does not act as a gello factory.
Finally, rights on pictures and videos belong to their makers. Today, many people think it is free material and they even had at multiwiicopter someone who stole a video made with their airframes and used it to promote a competitor equipment !!! From this date they decided to put the watermark.
Regards,
Gregory
greg, how high is the bottom of your frame from the ground when it sits up on those legs? I've been looking at that set and was curious if they'd lift it high enough......
I would say about 15 centimeters.
Gregory
T-Rex 550 FB
Hello guys,
Here is now the fourth (and last) video from Luberon, South of France. This is a small village called Viens.
Made with Multiwiicopter Scarab QuadOcta, Thomas Scherrer Long range, Paris Board and Gopro HD2.
https://vimeo.com/52315124
Cheers,
Gregory
T-Rex 550 FB
Hello,
Some of you may have seen part of the images included in this video. This is from my trip one year ago in French Polynesia, visiting Raiatea and Tahaa islands. In this short film, you may recognize Motu Mirimiri and Motu Cerran, Pk10 Uturoa and Raiatea Lodge Hotel. I finally found some time to do a decent edit...
https://vimeo.com/53263033
Gregory
T-Rex 550 FB
Hello,
I just uploaded a website, you will find there all my aerial videos, some still pictures, tutorials for fpv beginners or intermediate such as how to equilibrate blades, pictures of my different aircrafts,...etc. Scarab Hex Vampire build log is going to be there soon...
Thanks for being indulgent, this is the first draft and my first website since 10 years. Do not hesitate to give me advices or make suggestions.
It is there:
http://www.colibrilens.com
Gregory
T-Rex 550 FB
Hello,
Because the wiring for a Hex is more complex than a Quad, I decided to use the Voltair power distribution Board rather than the distribution harness. It is very easy, just solder the + and - of the 6 ESCs on the Voltair. I soldered also 2 JST plugs, one to supply the Andromeda board and the second as an extra spare supply. At the end, this gives a very neat design.
Then I start to re-organize the top deck. I will attach to the Quad frame the Paris board and the Thomas Scharrer NR600 receiver.
My idea is then to attach all the FPV gear to the new Vampire upper deck. The latest is not in carbon, to avoid blocking RF transmissions, RC RX or video TX. On that top frame, I then place my video TX, the Eagle Tree OSD and the Emcotec locating beeper. This beeper is use to locate the aircraft in case of a crash, it works with autonomous power in case main battery is disconnected.
I can fly the Scarab Vampire like that, if I don't need FPV - Line of sight, with lower weight and longer flight times.
Or bring the FPV deck wich will add the FPV features including video TX, Emcotec beeper and Eagletree OSD with GPS, RSSI, Baro alt, video TX, Emcotec beeper.
To connect the FPV deck, I just need to plug :
- The JST supply coming from the Voltair to the Andromeda v2. This andromeda supplies the FPV TX with 12 volts.
- The andromeda ground to the Paris board - so the leds of the andromeda are synchro to the Paris Led
- The LEDRING plug to Paris board to have the numbers of sats on my LEDRING
- The OSD main current XT60 plug to the XT60 coming from the Voltair
Buildlog is here:
http://www.colibrilens.com/multirotors/scarab-vampire/
Cheers,
Greg
Hello,
My Scarab Ysiix / Wookong has received a Zenmuse H3-2D. This is first tests and my first flights ever with a Gimbal. I am quite impressed by the results. Leaason learned: I shoud keep my fingers away from the Yaw stick as all small yaw movements are very noticeable now!
https://vimeo.com/71156585
Glambert7777
Gregory
T-Rex 550 FB
FPV : Scarab Multiwiicopter Hex-H Vampire, YSiix and Quad FPV Reconn
Hello,
I just completed the edition of my first film release from the material gathered this summer. This is done with the Sarab Vampire Hex & Paris board from multiwiicopter, no gimbal. Filming in low wind condition, even more important, in acro mode rather that level mode produces smooth video even without gimbal.
Special thanks to my wife who gave me the permission to film this provided that I woke up at 5:00 AM, drove 2 hours, filmed 30 minutes at sunrise, drove back and arrived on time to assist her giving breakfast to our 4 kids!
Cheers,
https://vimeo.com/73539452
Gregory
T-Rex 550 FB
I would not walk in that meadow where the future champions of Camargue bullfighting are raised, but this was the perfect mission for the Multiwiicopter Scarab Reconn. Camargue bullfighting is a style of bullfighting in which bulls are not armed...only men, from time to time. Glambert7777
https://vimeo.com/75904440
Gregory
T-Rex 550 FB
