Welcome To DroneVibes
S500 build ESC/Motor problem
Discussion in 'Recreational sUAS Flyers Discussions' started by JPG23, Dec 30, 2015.
  1. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 30, 2015 #1
    I'm in the middle of building an S500 frame quadcopter. So far I'm installed the components as follows:
    Frame: S500 quad
    Motors - 4X DJI 2212 920kv
    ESC - 4X Hobbywing Skywalker 40A
    FC: DJI Naza M Lite
    RX / TX - Walkera RX701 / Walkera DEVO 7
    I already went through the DJI Naza M Assistant and setup the TX to my preferences as follows:
    FMD - Off, Home Lock, Course Lock
    MIX - GPS Atti, Atti, Fail Safe
    AUX 2 - Gimbal Pitch
    RX Off - Failsafe
    Now that you know my setup, here's the issue I'm encountering; once I completed the assembly and programming, upon arming the motors (without props), the motors are starting at the "recommended" speed but when I accelerate they do not go anymore than 25-30% acceleration (my best guess). I've tried ESC re-calibration, new motors and reverse throttle setting on TX and assistant. I am stuck now and would love to figure out this issue today so I can get some fireworks footage tomorrow if possible.
    Thanks in advance for any tips or advice.
    Tags:
  2. Hoki
    Hoki Member
    544
    51
    11
    Dec 17, 2015
    Virginia
    Posted by Hoki, Dec 30, 2015 #2
    DON'T YOU NEED TO SET IT ON YOUR TRANSMITTER?
    2 people like this.
  3. Hoki
    Hoki Member
    544
    51
    11
    Dec 17, 2015
    Virginia
    Posted by Hoki, Dec 30, 2015 #3
    I HAVE A S500 FRAME I JUST GOT IT! mine is blue and black but I wanted black and white.
    2 people like this.
  4. Chalagi
    Chalagi Member
    588
    13
    1
    Jul 10, 2012
    Central Arkansas
    Posted by Chalagi, Dec 30, 2015 #4
    My guess is that your end points on your tx are not low enough on the "-" side nor high enough on the "+" side. Fix your tx this way and then re-calibrate your esc's.
    2 people like this.
  5. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 30, 2015 #5
    I did try increasing the scaling on the transmitter.
  6. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 30, 2015 #6
    Cool, they're beautiful frames, that's why I'm building this one. It looks great.
  7. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 30, 2015 #7
    That's a great point. Here's what I have now, I just checked the TX and it says 100% on +/- in the travel adjustment setting. That's the default setting, what should I try putting it to?
  8. Hoki
    Hoki Member
    544
    51
    11
    Dec 17, 2015
    Virginia
    Posted by Hoki, Dec 30, 2015 #8
    2 people like this.
  9. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 30, 2015 #9
  10. Hoki
    Hoki Member
    544
    51
    11
    Dec 17, 2015
    Virginia
    Posted by Hoki, Dec 30, 2015 #10
    look at all the parts I got I posted some pics and links to everything I ordered in the other thread
    2 people like this.
  11. Chalagi
    Chalagi Member
    588
    13
    1
    Jul 10, 2012
    Central Arkansas
    Posted by Chalagi, Dec 30, 2015 #11
    On your tx endpoints run the -100% down to say -115 or -120 and on the +100% said run the end pint to mybe +115 or +120. Then recalibrate your esc's and see what happens.
    2 people like this.
  12. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 30, 2015 #12
    Sounds awesome, I'll take a look at it.
  13. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 30, 2015 #13
    I did that just now and have concluded that the problem is the Naza FC because the motors are all spooling up without props now but as soon as I put props on (proper rotation) they all start together but upon throttling up to take off, one side stops.
    Any ideas?
  14. Hoki
    Hoki Member
    544
    51
    11
    Dec 17, 2015
    Virginia
    Posted by Hoki, Dec 30, 2015 #14
    Could there be a short
    2 people like this.
  15. Chalagi
    Chalagi Member
    588
    13
    1
    Jul 10, 2012
    Central Arkansas
    Posted by Chalagi, Dec 30, 2015 #15
    Check battery voltage in each cell and the overall battery voltage. If running a 3 cell 1300Mah battery and 2 cells are below 3.0 it would act that same way.
  16. Chalagi
    Chalagi Member
    588
    13
    1
    Jul 10, 2012
    Central Arkansas
    Posted by Chalagi, Dec 30, 2015 #16
    Try taking your end points to +/- 115 or 120
  17. Hoki
    Hoki Member
    544
    51
    11
    Dec 17, 2015
    Virginia
    Posted by Hoki, Dec 31, 2015 #17
    check your trims
  18. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 31, 2015 #18
    So guess what? Turns out the Naza is just fine (what a relief) but I have 2 bad esc's, I got the other 2 to calibrate and accelerate full speed with and without props, the other 2 shutoff and stutter at 67% throttle. They're old and have been used on 2 other builds, so I should be getting the new ones in on Monday. Oh well, I'm using my syma x8c to record fireworks tonight, it's a stable craft but no gps.
  19. Hoki
    Hoki Member
    544
    51
    11
    Dec 17, 2015
    Virginia
    Posted by Hoki, Dec 31, 2015 #19
    Im gonna do some nite flying with my x8w but can someone go look on my other thread n help meeeeee
    2 people like this.
  20. JPG23
    JPG23 Member
    31
    8
    1
    Dec 27, 2015
    Houston, TX
    Posted by JPG23, Dec 31, 2015 #20
    Excellent, I'll be using my ASX ActionPro-X and the SYMA lifts it pretty well for about 11 min.
Loading...
Share This Page
Loading...
