http://www.0577mx.com/products.asp?tp=new , these are latest products ,The retractable landing gears is waiting for long time for customers . thanks a lot
thank you for your questions , about the landing gear , you frame is T960 ,so you a re need buy the TL96030 landing gear , the controller TL8X002 , and X Metal Damper Mount TL8X007
and the installation , you are need to make the holes on the palte , then used the damper mount for it ,
thanks a lot
tarot : Peipei
Address : NO.1 PuZhou SanQi LuCheng DISTRICT, WENZHOU, CHINA
TEL : +86-577-88989980
FAX : +86-577-88119930
mobile :+86-18867785883
Email :tarotrc@hotmail.com
SKYPE : tarotrc@hotmail.com
website: www.tarotrc.com
Thanks very much for the reply, Peipei,
I did not know about part number TL8X007. I'll check that out. Thanks for that information.
The question I have now is - since the inside holes are so close together (20mm), if I drill holes in my bottom plate, won't I be drilling into the boom as well? Or do I need to remove the boom first? And even if I could somehow drill the holes without putting a hole in the boom, how would I fasten the screw? Seems to me that I will need to remove the boom no matter what. Is that correct? And if it is, is there a way to remove the boom without completely removing the upper plate?
Thanks!
