retractable landing gears
TAROTRC
http://www.0577mx.com/products.asp?tp=new , these are latest products ,The retractable landing gears is waiting for long time for customers . thanks a lot
this T series retractable landing Gear is used for all Multi-copter , you can DIY by yourself accord to your Frame , maybe you can make some holes on your plate , The state intellectual property has been awarded the TAROT model.,ltd two patents. Any units orindividual without the license holder manufacture 、copy 、use and sale the product will be patent lawsuit., our price have advantage than other Brand , and we will put a full set of the Sport series Frame, www.0577mx.com is our website China , you can visit it , thank s o much ,
TAROTRC
Product Description:
Full Metal medium-sized electric retractable landing gear using 6061T6 aluminum CNC machining process for T810 / T960 / T15 / T18 / 810sport / 960sport and other multi-axis DIY use unmanned aerial vehicles (need to add drilling two M3 mounting holes, optional Long metal silicone damping seat 4). This is the similar products in the highest degree of product integration, the overall design of the structure is simple, quick and easy installation, small footprint. Exclusive ordered large torque motors reliable and durable performance.
The state intellectual property has been awarded the TAROT model., Ltd two patents. Any units orindividual without the license holder manufacture, copy, use and sale the product will be patent lawsuit.
patent number patent number: 201430262458.5
patent number patent number: 2014204282854
Related Item:
Electric retractable tripod controller TL8X002
New electric retractable landing is TL65S01
Small electric retractable landing is TL65B43
Small electric retractable landing gear group TL65B44
Medium-sized electric retractable landing is TL8X003
X series electric retractable landing gear group TL8X001
Department of electric retractable landing gear group T TL96030
Large electric retractable landing is TL4N001
Large electric retractable landing gear group TL4N002
Product Specifications:
Pipe Clamp on Φ25MM metal (39 × 12.3 × 10MM) pitch Φ23MM
Φ25MM metal hose clamp under the seat (39 × 16.3 × 10MM) pitch M28MM
M3 × 20MM Cup hex head screws × 2
The M3 × 12MM Cup Head Cap Screws × 2
M3 × 8MM big step screw cap × 2
Full Metal medium-sized electric retractable landing control group × 1 (115 × 34 × 36.5MM) 77G
Φ4 × 6MM rivet × 2
Φ25MM 3K pure carbon tube × 1 (Φ25 × 23 × 349MM)
Φ25↔Φ16 plastic adapter seat TL96017 × 1 (Φ25 × 45MM)
The M2.5 × 25 × 1 cup head Allen screws
The M2.5 × 30 × 1 cup head Allen screws
M2.5 slip nut × 2
Φ16MM 3K pure carbon tube × 1 (Φ16 × 14 × 445MM)
Multi-axis shock tripod set TL96022 × 2 (Φ16 × Φ25.8 × 31MM)
Can you tell me what is involved in the installation on a T960? I have a couple questions:
- I have heard that the outer holes do not match up and some people are drilling out the holes from the original landing gear. This does not seem wise to me.
- Are the optional Damping seats a solutions? Will they work with the T960, or are they designed to only work with the X8?
- Would I need to completely disassemble the top and bottom plates to install this gear?
Thanks!
TAROTRC
thank you for your questions , about the landing gear , you frame is T960 ,so you a re need buy the TL96030 landing gear , the controller TL8X002 , and X Metal Damper Mount TL8X007
and the installation , you are need to make the holes on the palte , then used the damper mount for it ,
thanks a lot
tarot : Peipei
Address : NO.1 PuZhou SanQi LuCheng DISTRICT, WENZHOU, CHINA
TEL : +86-577-88989980
FAX : +86-577-88119930
mobile :+86-18867785883
Email :tarotrc@hotmail.com
SKYPE : tarotrc@hotmail.com
website: www.tarotrc.com
thanks a lot
tarot : Peipei
Thanks very much for the reply, Peipei,
I did not know about part number TL8X007. I'll check that out. Thanks for that information.
The question I have now is - since the inside holes are so close together (20mm), if I drill holes in my bottom plate, won't I be drilling into the boom as well? Or do I need to remove the boom first? And even if I could somehow drill the holes without putting a hole in the boom, how would I fasten the screw? Seems to me that I will need to remove the boom no matter what. Is that correct? And if it is, is there a way to remove the boom without completely removing the upper plate?
Thanks!
Thanks!
Update: I just checked out TL8X007, and I'm not sure how this would help me. It only accepts a 12mm tube and the boom is 25mm. How does that assist in mounting this landing gear? Could you describe how this part should be installed?
TAROTRC
my English is bad , I'm not sure that you can understanding , firstly, about the 960 frame ,if install the landing gear ,the parts of TL96014 Damper is short , so need the longer than it and hang the 12mm tube ,secondly ,about make the holes , i think you are need to remove the boom and plate , it's make the holes on the under plate , if not to do it ,how would you do it ?you are need to measure the size of the holes then to make it 。
hope it can be useful for you
thanks
tarot :Peipei
