Replacement Props
aWanderer
Hi all,
Any recommendations for shops in Canada to get replacement props for the F450?
Mine is the stock ARF kit.
aWanderer
Alright, perfect then. I have no idea what props to buy for the DJI F450 ARF kit, can you tell me what will work on it? Also, the stock props have a flat spot inside. Do all props have this?
aWanderer
Perfect. I'm going to order a bunch real soon here. Thank you for replying. I am using the 8x4.5, have not tried the 10" yet, but I think I will order both sizes.
are those colored ones able to be 8mm bore? the apc can, but have to be drilled. the precision hole is the right side to slide on, but that skinny stuff near the front has to all come out. I ask cause i got 12 sitting here like those that the outside of the hub is 10mm, wouldn't dream of trying to drill it out with a 1mm hub left
no other props but xaircraft and dji have the flat spots on the hub
GotHeliRC
http://gothelirc.com
Hi,
The 9x4 and 10x4, 11x4,12x4 on this is the same as apc... the inner hole is 6mm and can be bore out to 8... the OD is 12.60, so if you bore out to 8, you should have 2mm left each side, The top is pretty much flat...
Here, I attached some pictures.
PS: I am sorry about the mistake, I didn't realize the DJI one need 8mm. (but if it work, I don't mind on boring it to 8mm if request)
