what's wrong with your current setup ?
it's not a question of what others are running, it depends on how your machine is flying.. mora than frame dimension, weight and hover throttle are more important.
if you are hovering at 40-50% and the quad is responding good and not sluggish , then i don't see why you would have to change props. If instead you hover at 40 or lower % then probably you can loose some thrust in order to have motors in their better range. I dont know if you are at 3s or 4s lipo, but with a 4s and 11" props and 885kv motors, you should have some very good thrust.
my 2c.
