just spoke to Adam at Quadrocopter.us.....he said to take the unformatted new card and insert it into the Nvai board and then run a firmware update. in the process of updating the firmware the board gets formatted.
bart
I would check it is recording.. Just plug it in, calibrate and spin the motors a couple of times and by hand move the copter up and down the garden.. Then go look at the log file to make sure it is recording correctly.
BTW make sure your props are OFF!
I would also recommend after each days flying that the SD card HAS THE LOGS REMOVED SO THAT YOU DO NOT FILL IT INADVERTENTLY.
To see the affects of a SD card that can not record the data go check out my youtube channel.
This maybe a stupid question but I'm having trouble connecting to the Navi.
This is what I did.
1) I unplugged the 10pin plugs from the Navi and Flight control,
2) I then plugged the MKUSB ribbon into the 10 pins on the Navi.
3) Opened up the MKTools
4) Added the jumper to the MKUSB, have also tried by connecting the main packs instead of jumper but still no go
5) MKTools has a message saying no connection
I can connect fine through the XBee but not the USB
