Mikrokopter Power is jumpy with GPS pH engaged
Has anyone experienced brief power outages with GPS PH engaged? It sounds as if I'm getting very brief loss of power blips after I engage GPS PH with my MK Okto.
Anyone ever hear of this?
Thanks,
Bart
I'm not using an SD card. I probably should use one but I'm not.
Bart go back here and see if out helps
http://www.multirotorforums.com/showthread.php?175-GPS-Hold-issues
It sounds just like whatI was experiencing but my problems were defo the SD card..
Whathave you done since your last good flight?
Check the plug on your compass thigy that it has not come loose in the nave board.
Sandor has zip tied mine in. I have seen this as a problem on other threads else were..
Dave..
PS hope you sort it for your shoot today.. Good luck
