photohigher-b
Brendon
Hey guys!
After upgrading my skyline rsgs firmware to 1.2.2 and follow the harness modification and setup instructions, i did not get any response with the roll servo. it is not running while connecting to the gyro. but when i test the servo(bypass) it and its working. Do you have an idea?
TIA!
Hi Gyroster,
Check that the signal(white) wire on the Roll Servo lead is not damaged and still goes to the second pin on the bottom from the left.
If you've got a multimeter check that you are getting 5V(or whatever voltage your power supply is) on the Roll Servo lead between the black and red wires. If you've still got the Tilt Pot servo end you chopped off you could strip the wires on that and plug it in to the Roll Servo lead just for the purpose of measuring the voltage (It's tricky to get multimeter probes inside the female servo plugs without shorting anything)
Which version of the gyro do you have? Could you post a photo of your modified harness?
Brendon
