Hi Ed,
Have you set the GoPro to put live video out the side?
SETTING VIDEO LIVE FEED ON / OFF
You can set your camera to send a live video signal out the side TV or HDTV ports by toggling the VIDEO
LIVE FEED setting on and off . Video Live Feed via the USB port is not supported. When Video Live Feed
is set to OFF (LFF) the camera will switch into video / photo playback mode when one of the included TV
cables are plugged into the camera. If Video Live Feed is turned on (LFO), the camera will stay in normal
camera mode when plugged into a TV and will send a live video signal to the TV. Plugging in the component
cable will send an HD video signal out from the camera, and plugging in the composite cable will send a
standard defi nition signal out from the camera. Video Live Feed On allows for plugging the camera into
wireless transmitters and TVs for live viewing from the camera. NOTE: If the component cable is used to
send live HD video out from the camera, and you begin simultaneously recording HD video to the SD card,
the live video feed will be reduced to standard defi nition as the camera cannot record and transmit HD video
at the same time. If you wish to have an HD live video feed from the camera you cannot begin recording HD
video to the SD card. If the composite cable is used to send standard defi nition video out from the camera,
then the camera can simultaneously record HD video to the SD card.
Symbol on LCD Screen Function
(default setting) Video Live Feed OFF.
Video Live Feed ON.
1. Press the SHUTTER button to toggle between the LFF / LFO choices.
2. Press the POWER/MODE button to save whichever setting is showing on the screen
and continue to the next feature option.
Good luck with it.
Bart
