Need advice running 2 fpv on same copter. Newbie to FPV
Hello,
Sorry if this is a stupid question.
FPV 1:
Video Goggles - FatShark RCV922 5.8GHz. Goggles for my camera operator gimbal. Only used for camera framing AP shots : 5.8GHz
Antennas - Bluebeam Whip Set
Camera - RMRC-700XV NTSC
Video Transmitter - ImmersionRC 600mW 5.8GHz
FPV 2: Iftron YellowJacket 5.8 Pro Diversity Receiver
Stinger 5.8GHz Pro 250mw AVD Transmitter
My intention is to use this 2nd system (for my piloting needs) attached to my Ground station (Pic below) for better orientation etc...
Since both systems are 5.8GHz is there ANY way to use both?
Any suggestions are greatly appreciated.
My Pilot View Video Ground Station:
Thanks!
I tried two immersion 5.8 on total other channels and i had a greatly reduced range, like 200 feet was fine and it shut off at 220 feet. i'm not sure if the different types of boards will work any better. let us know what happens, it's obvious, good part is just kills the video reception and not rc control, at lest in my case.
drsf
Not sure if it might help, but i'm having a crack at this problem via changing to wifi
On-board the video inputs are going into a beagle board, getting encoded and forwarded through a wifi dongle as mpeg.
Obviously this effects range, but allows for diverse functionality (well I hope). Range i'm hoping can be optimized via directional antenna. Will require some ground station processing too.
Again I'm just getting into this system, can't yet vouch for it, but may be an idea.
-Dan
